Felicia Thermostat
My 1.3MPi 2001 Felicia is running cold so need to replace the thermostat but struggling to find the correct one. Mine is quite a narrow diameter and is held into the housing via a circlip whereas all the ones that the local car shop can supply are bigger and the housing is different and wont seal on my car.
I've had a look through Jorily but cannot seem to find the correct one.
Can anybody point me in the right direction to get a replacement thermostat for mine?? :yes:
I've only ever replaced the stat with the housing as the housing had been broken. If yours is held in with a circlip then it's the later version which Jorily supply so ask which one will do the job - they should know as they supply that version with the housing.
