Rear windows don't stay up :(
Hi all i'm pretty sure it's a common fault but my rear windows seem to intermitantly lower on there own it's only a little but annoying when your can here a wisper of road noise and when you wash it and get water in throught the window :( and cures?
Edited by matt_j
Bit of string tied around the window winder and the grab handle?
Assuming no-one uses the rear seats of course.
Take the handles off, the back collar slides to one side and they pull off.
See if it makes a difference, if it does put the handles back on in the straight down position, bet they don't drop then.
Are u trying to say tht they drop due to the wait of the winder
handles?
Edited by matt_j
handles?
if the handles are to the side when you go over bumps the window works its way down if they are straight down should be ok
Another one for doing as techie has said..
Sure I've seen something about it on Elsa..
handles?
Pretty much, acts as a lever.
Ok dudes jus sounded a bit silly thought you were going to say the weight of the handle pulls it dwn the mechinism cnt be very strong then
