Legacy Amp 600w
Found some more of my car audio gear.
1st is a Legacy LA 460 600w amp, 2channel amp. Says 2ohm stereo stable, electronic crossover. It has input level adjustment, Full/LP/HP crossover switch, bass boost upto +12db, low pass adjustment and high pass adjustment and is a compact size. I cant find the lead for the high level input but i always use the rca lead anyway.
2nd is a Boss amp, model 600n. says 300W x 2 channel, think its 600w total. Sub woofer adjustment from 50hz-150hz, mono/stereo bridge switch, sub woofer on/off switch and input adjustment. Its got a few marks on the top but it could be painted. The side caps are missing but this doesnt affect the operation in anyway, just makes it easier to be sunk into an install properly so all you would see is the top fins.
Also got an rca lead to go from the stereo to an amp and a fused power lead and splitter and various other bits of wire.
The legacy amp is the newest, probably used for less than 12 months as not longer after i fitted all this i decided to swap the car for an MR2!
Got two rockford fosgate subs and vibe qb69 speakers advertised too, maybe do a deal on it all.
Open to offers on it all
OFFERS FOR ALL AUDIO, NEED IT GONE
BUMP- NEED ALL OF THIS GONE ASAP, ALSO ON THE BAY
Hi- how much for the blue RCA lead?
Its on ebay as a package with the amp. If it doesnt sell ill get back in touch mate.
Thanks. Really need a decent one!
