need a network tech
i have a wireless network in the house but the signal only covers half the house ive got a network cable run to the other end. what im wondering is can i buy something that i can plug the cable into and it comes out as a wifi signal
Or simply buy a wireless bridge?
Hi,
i may have a wireless Bridge floating around, let me have a look over the weekend and come back to you.
im quite good with computers always build myown but ive never really done any work with networks can what im lookin for me done with an old router i have.
If it supports bridging, then yes.
What router is it? What is the other router?
There both netgears cant remember the models and ill not be home untill monday now that i know what it is im looking to do i might get on a bit better.
As long as you have a network lead to connect to the second router you are fine.
Find out an IP address for Router 2 e.g. Router 1 = 192.168.1.1 Router 2 = 192.168.1.2 DHCP Range on Router 1 = 192.168.1.3 - 192.168.1.254
Login to router 1 and change the DHCP range to exclude router 2 IP address
Plug your second router into a machine not connected up to the network and login
Give Router 2 the IP address e.g. 192.168.1.2
Setup Wireless Settings SSID and Password
Turn Off DHCP on Router 2
Reboot Router
Plug the network cable into one of the 4 LAN ports on Router 2 NOT the WAN/Internet Port
Reboot router 1 and router 2
Search for router 2 and connect.
I have the same setup in a remote area in our building using Netgear Routers
Hope that helps!
Edited by s80wkr_vts
Thats pretty detailed ill give it a go next week thats very much for the replies.
use a wireless access point, if not any old wireless router will do, turn off the section that sets it to act as a DHCP server and connect the cable to one of the LAN ports and all will be well.
John
Should have bridging then.
You just need a Wireless Access Point, this will patch into your existing router using the network cable you mention that is already installed, power the WAP up and you will see two different wireless networks.
Theoretically it will be as easy as that!
http://www.aria.co.uk/Products/Networking/Wireless/Access+Points/TP-Link+54Mbps+eXtended+Range+Wireless+Access+Point+%5BTL-WA500G%5D+?productId=44503
About £20 quid, I haven't used these so couldn't comment on quality but it is only £20!
that looks exactly like wot i needed but i managed to get the spare router set up and working does the job and i can use the extra ports to plug in extra devices thanks for all the help guys much appreciated.
