Fault code 00496; Xenon level sensor
Got this from a scan of my car:
Address 29: Left Light Labels: None
Part No: 1U0 941 651
Component: EVG GDL + AutoLWR 0002
Coding: 00005
Shop #: WSC 31480
VCID: F0F25C50B0B8B34
1 Fault Found:
00496 - Sensor for Vehicle Leveling; Front
07-00 - Signal too Low
Is there a label file for this controller anywhere?
Is there a way of looking at the value from that sensor? What measuring block channel is it?
Check the connection and condition of the sensor (Fitted Nearside inner wing)
Edited by VAG123
Saw this from Uwe on another forum (Subdriven)
Post values from Measuring Block group 002.
Field 1 should be the voltage from the front level sensor and it should be between 1.6 and 3.0V.
Field 2 should be the voltage from the rear level sensor, which should be between 2.0 and 3.0V.
-Uwe-
I take it that's measuring block 2 when looking at module 29?
thanks
Martin
Also, anyone know of a procedure for setting level on mk1 Octavia? The ones on the Ross Tech wiki only seem to relate to newer models.
  • 3 years later...
The error occurred to me after I mounted adjustable suspension and got off the car -10cm
