Alpine KCE400-BT Bluetooth kit.
After getting rid of my headunit i have my bluetooth kit up for grabs,
only had it in the car for a month or 2, and worked perfectly.
This is one of the units that has been sent back to Alpine after the recall so it is in perfect prder.
Comes with everything you need, mic etc.
All you do is plug the unit cables into the ones off the unit, and attach the earth cable to the earth on the headunit plug.
can be installed in under 10 mins.
cost £120 from CAS,
so ill send this out posted for £100, or collect from RG40, ill even install it for a tenner if you come to me.
Any questions just ask, please check before buying that headunit supports the kce400bt addon.
bumps
Whats the lowest you'll take posted?
