Fabia with flickering head lights Help!
Hi all
I have a 2000 year 1.4 Skoda Fabia it has flickering head lights and internal lights it also is not idling properly. I have just had a new alternator fitted and that hasn't fixed it.
The garage is still investigating and are going to bring in an electrical expert but i cant afford to spend much more money on it.
If anyone has any idea on what courses these problems please let me know i would very much appropriate any help.
Probably best in the Fabia section rather than the Felicia forum.
But have a search for battery issues and there is a long thread on PAS problems in the right section, it ill probably she'd some light on your issues.
Is it charging? Does the battery light come on with ignition? How is the battery? Earth cable? All things to consider.
I would suggest the power steering pump too, but you need to be a bit more descriptive than just saying flickering? Also as above, try the fabia section for more relevant info.
My first thought is of the steering angle sensor having failed. This should throw fault codes saying things like "Steering angle - implausible value".
Moved to the fabia forum! :D
what size/capacity is the battery?????....should be at least 60ah....... B)
