dash binnacle intermitent
how do folks,
got a 1.9td x plate and my dash binnacle is so intermitent, loose the rev counter,fuel, temp and speedo, but the rest of the lights etc work,
ive got a binnacle from 03 octavia,
so first questions are
will it swap over ok ?
if i remove the binnacle will it effect the immobiliser like the mk4 golf ?
feels like speed cameras are a russian roulette lol
thanks big jim
Yup swapping the dash will cause immobiliser problems as its coded to the ecu you could try re soldering your dash to fix your problems think there's a how to somewhere. Other options is removing the immobiliser which requires coding. I think shark are able to supply dashes without the coding for the ecu or something lol
swapping will require recoding of the new unit (yep, immo problem)
would solder it. 1h job
thanks for the replys guys, seems like the soldering gun will be comin out this weekend :thumbup:
cheers for the help .
