Octavia vrs starts and dies when turning lughts on
Hi there i am hoping you could Please help me with a problem i have with my mk1 octavia vrs 1.8t.
The problem i keep having is that when i start the car is starts fine and idles fine but as soon as you try to turn the main dipped lights on it dies out and all the dashboard lights go off and are unavailable even when turning key off and removing after a while it comes back on normaly when you touch the wires from the fusebox on top of he battary, all the side lights and green dashboard illuminations work but the car will not start. Please if you can help it would be greatly apreciated as i pove my vrs and it keeps happening
Thanks chris.
Sounds to me like you have a problem with the fuse box on top of the battery. Have you opened it and checked that it hasn't melted? Usually the alternator cable corrodes and causes the fuse box to melt on the inside. To fix you'll need a new alternator cable and new fuse box and atleast 1 fuse
you may be able to repair the cable with solder if it isn't too fried lol
Yer checked everything and all looks ok i changed the lead to the starter motor last night which of the cables goes to the alternator?
Thanks chris
The one at the end nearest the engine, left hand side looking at it.
To me it does sound like something is either loose or over heating
Common problem the battery fusebox wiring and loom is burning out, you may be able to repair if not too damage
2011-12-21 14.04.54
Edited by VAG123
Thanks for all the help guys the fusebox isnt melted like the picture sent to myself but the black whire on the left of the fusebox does seem very loose just before the connector compared to the same sized red one next to it.
Is it quite easy to change the altornator lead as i have one spair already or is it better for me to get someone to do it for me
