Airbag light faults?
what can cause aur bag light to come on?
Sent from my GT-I9000 using Tapatalk
A broken airbag.
That was helpful! I have one on too and I think it could be a connection issue. It came on not long after I changed the battery. I do not know if this is relative.
They normally come on after a plug has been disturbed, ANY airbag plug that is removed and the ignition turned on will put the light on.
You then need a VCDS owner or dealer to turn them back off again (once the 'problem' has been rectified) if you are unsure which airbag has set the warning off then a scan will confirm the faulty airbag.
yep a total loss of power or poor battery voltage (ie disconnection) could cause the light to show.but just needs checked and then cleared
phoned local skoda garage and said they will sort it out, under warrenty so... i think i justed knocked the or something like it
