fabia lowering springs
does anybody known where i can get fabia lowering springs from that give you a drop more than 30mm
thanks
james
If i remember correctly, Eibach do a springset, called lowline or something that will drop a car about 60mm... atho not sure they do a setup suitable for a Fabia... and i definately wouldnt advise it on a TDI/RS as the engine hangs so low
thanks for that only had my fabia a month so still learning things about them
regards
james
H&R have a spring set too...I have a set that lowered mine about that much or more...can't remember...
Eibach do a -30mm kit as do H&R. I don't advise going any lower as your sump guard will hit the floor.
And also make sure you get the vRS ones ;)
Chris
Chris
:finger::D
There was a set of cobras 50mm on ebay the other day, think they were going for good money
Only way to be able to "test" the lowering is get some adjustable coilovers and then experiment with various heights to see how they work with potholes/kerbs/speed bumps, etc.
At least thats what I'll be doing soon. :D
thanks
james
Take a look under the car and see how close the sump is to the ground even on standard springs. The PD TDI is a tall engine! I think Jason's right - fit coilovers then you can set them really low for posing and raise them again for normal driving...
  • 2 years later...
ive got some 40mm cobra springs, which were on my vrs for a month, still like new. gonna get some eibachs instead, let me know if your interested??
