knocking and service light
Just got a 1.4 classic, when i turn at slow speeds there a litle knocking and i also when i go over bumps in the road, wondering if it will be the suspension bushes? also how do i knock the service light off as i replaced everything and changed oil and cant knock light off
The knocking Is proberly the drop link bushes. As for the service light I ant got a clue but hope this helps
ok cheers im going to get it on the lift and give it a check out and also do fabias have a rear window washer and ifso how do youu operate it
Same stalk as front but you push it away from you
ok, think mine must have been took out as i tried that and doesnt work, are they hard to fit and how much would they be?
