Cheers Piotr at ABC
Just thought I would post my positive experience after my visit to ABC Car Service in Leeds.
I had a slight off centre wheel allignment issue after having some tyres fitted and tracked at a local KF in Hull. So after much research on Brisky, and many positive reviews I headed up to see Piotr at ABC (an hour from Hull).
The whole experience was very friendly, laid back, and most importantly very honest! and Piotr certainly seems to know his stuff! coupled with a very fancy John Beam 4 wheel allignment machine.
After visually examining the wheels Piotr first swapped the front two wheels, and this made a big difference (you could see the individual tread blocks had worn on a slight angle, and looked almost like a saw. We test drove after swapping and found an improvent in handling, but the steering wheel was still off centre.
The car then had the 4 wheel allignment
It turns out the allignment of the wheels on my car were mostly OK, and only the front o/s side was slightly out of spec, nothing major but the toe was out enough to cause the problem I was experiencing.
Piotr easily put this right and test drove again to ensure I was happy.
All in all I have to say a very pleasurable experience with a good result, and very easy on the wallet. I would definitely recommend even if you're not local, easily worth an hour or two drive.
Cheers Piotr, probably see you at some point in the future.
