Engine Fans On
Hi
I have a 2007 1.9tdi Octy Elegance Estate, today the engine fans are staying on for some reason, VCDS shows no issues and the only thing i can see is an oily substance coming out the top of a sensor on the left side front of the engine bay (looks like it attaches to an aircon pipe) when i move the wires there is a hissing sound - can anyone help. To clarify the fans only run when ignition is on
thanks
1271-sensor
Edited by psycho6149
Do you have climate? If so is it usually set to auto? This spins the fans on constantly to retain the set temp I think
yep i do have climate control but this happens even when set to off
bump
Had a constantly running fan on mine just before the warranty ran out. Had it looked at and the under bonnet loom had corroded - done on warranty and no problems since.
Edited by etskoda
