Interior light question
Hello there my forum search is playing up does anyone know the interior bulb sizes for the vrs as I am getting them replaced with LEDs ones, I'm after the map readers, the centre bulb in between and the boot too many thanks in advance
I believe it's 2 X w5w for the map readers and a 39mm Festoon for the centre bulb.
It's discussed at length in this thread.
501s for the map readers and a 44m 264 bulb is what I used
Thankyou for the replies cheers
yeah I bought a 39mm for the interior but it was too small.but luckily it fitted for the number plate bulbs
I have a 39mm for my fabia too. You need to bend the pins inward so that the bulb will hold. If you don't mind the hassle of exchanging it, then go for it.
ah top tip ! :-)
