Is there a HID light kit available
The dipped beam lighting is very dull when driving, is there a HID kit available for the Superb
If available do they need to be canbus or none canbus??
Edited by skippy41
There are LOADS of kits. Dipped beam is H7, so you basically need a H7 aftermarket HID set. There is no CANBUS control on the MK1 Superb. You will need to take power directly from the battery though and remove the fault BIIIP sound on broken bulbs via VAG in order to make it work. Otherwise the dipped beam wont turn on correctly, when starting the car.
If i remember correctly it's called a HID relay harness or something.
Is there a how tp for fitting them available??
