Help with fault codes
Hi all, i am fairly new to VCDS, today evening i scanned our Octy 2 and it came up with some (to me strange) fault codes in Immobilizer and door electrics. I checked it on RossTech Wiki but still dont understand what it means especially that car drives and feels ok, especially with door electrics everything is working (puddle light,indicators,mirrors) as it should.
any helpful info would be much appreciated. :sweat:
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 03C 906 056 DK HW: Hardware No
Component: MED9.5.10 G00 8344
Revision: --H08--- Serial number: SKZ7Z0F3662758
Coding: 0000071
Shop #: WSC 73430 790 00000
No fault code found.
Readiness: 1110 0101
Address 03: ABS Brakes Labels: None
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1Z0 907 044 H
Component: ClimatronicPQ35 084 0305
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000004277523
Coding: E18E0F011004140000110D00000000000009FF075C
Shop #: WSC 04876 004 06900
Part No: 1Z2 955 119 A
Component: Wischer SK351 012 0401
Coding: 00063477
Shop #: WSC 04876
Part No: 1K0 955 559 AE
Component: RLS 290606 014 1201
Coding: 00471077
Shop #: WSC 04876
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD0LPAS4
Coding: 0020788
Address 16: Steering wheel
Cannot be reached
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1Z0 920 942 B HW: 1Z0 920 942 B
Component: KOMBIINSTRUMENT VD1 1612
Revision: V1612038 Serial number: SKZ7Z0F3662758
Coding: 0007401
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001066011208
Coding: 3D3F074007001303
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO VD1 1612
1 Fault Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Mileage: 99910 km
Time Indication: 0
Date: 2000.00.00
Time: 08:35:57
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 005 0944
Coding: 0000758
1 Fault Found:
00120 - Outside Warning Light/Door exit Light Driver Side
012 - Electrical Fault in Circuit
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.068 H07 1806
Shop #: WSC 02069 000 90108
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0202
Revision: 00020000 Serial number: 00000000000000
Coding: 18801A085283407F3F02050FC0084F96907C80
Part No: 1Z0 951 171
Component: Innenraumueberw.008 4801
Coding: 00000000
Shop #: WSC 04876
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H05 1501
Component: NGS n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Component: Tuer-SG 005 0934
Coding: 0000758
3 Faults Found:
00121 - Outside Warning Light/Door exit Light Passenger Side
00110 - Right Mirror Turn Signal Lamp (L132)
012 - Electrical Fault in Circuit - Intermittent
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1Z0 035 161 C HW: 1Z0 035 161 C
Component: Radio FO3 019 0034
Revision: 00019000 Serial number: SKZ7Z3F0006601
Coding: 0000402
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 J HW: 1K0 959 703 J
Component: Tuer-SG 005 0905
Coding: 0000144
Shop #: WSC 73430 790 1012544
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 J HW: 1K0 959 704 J
Coding: 0000144
Address 76: Park Assist Labels: 1Z0-919-283.lbl
Part No SW: 1Z0 919 283 B HW: 1Z0 919 283 B
Component: Parkhilfe 4-Kan H04 0020
Coding: 0000001
End ---------------------------------------------------------------------
How old is the car? I assume it is not the one in your profile (2006) as the scan shows Park Assist.
What software version are you running? it does help when posting scan results to include everything, including the date / software etc.
yes that's the car (2006), missing info from log:
Tuesday,28,February,2012,21:46:04:60804
VCDS Version: Release 908.0
Data version: 20090830
Clear everything down and rescan.
Your missing a few addresses there, looks like the door wiring loom has been unplugged at sometime. If the door light at the bottom is unplugged it will record a fault.
will try that and yes i unplgged the door lights as i changed the bulbs for LEDs, any info on that immobilizer fault, please?
See if it clears down, I'm assuming the car starts ok?
yep, without any problems. mamy thanks for your help so far guys
Any reason why you are running sw 908.0?
If it's a genuine interlace you should update it, if not the interface may be at fault?
