front wiper issues
guys,
anyone else had issues with the front wipers not resting at the bottom of the screen when on intermittent and not turning off when switched off using the stalk?
only way to stop them is to kill the igntion and pull the key out.
It could be the wiper motor or relay 377 which is on the relay plate (under the dash, above the pedals).
A quick test for the wiper motor parking switch, is to put a ANALOG voltmeter or test light between pins 2 and 3. You should see a 'blip' every time the wipers pass through the parking position.
cheers for that :)
i've done a google search and it appears it could also be due to water ingress to the rear wiper motor so going to check that first.
I was going to suggest water into the rear motor assembly....
