Retrofit Columbus in Yeti with Soundsystem
I have just installed a Columbus in my Yeti. It's 2010 DSG Elegance with th 12 speaker SoundSystem. Originally had Bolero. All appears to work OK, except I get electrical static crackle through the rear right speaker. This occurs even when the Columbus is off and the keys are out of the ignition. The crackle is there 24/7 unless I unplug the Columbus from the car using the large multiplug on the rear of the Columbus. I've had the coding checked and the following errors have been reported. Not sure what to do though.
Don't think I can leave the unit in the car as I presume its running or crackling continously, and i'm sure will drain the battery. Doesn't look like the battery drain issue reported elsewhere because the gateway is AE revision, but I don't know now.
Help needed.
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 AE HW: 1K0 907 951
Component: J533 Gateway H06 0112
Revision: H06 01 Serial number: 300310F2002703
Coding: EDA17F06500603006303
Shop #: WSC 33361 790 00999
VCID: 6AD049CF4564C83
2 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
004 - No Signal/Communication - Intermittent
01304 - Radio
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3T0 035 680 A HW: 1Z0 035 680 A
Component: RNS-MID H04 2664
Revision: AB001001 Serial number: SKZ6Z7H8111154
Coding: 000204000000009100
Shop #: WSC 12345 123 12345
ASAM Dataset: ------------------------- ------
VCID: 2E5885DF790C643
3 Faults Found:
00856 - Radio Antenna
011 - Open Circuit - Intermittent
00821 - Antenna 2 for Radio (R93)
00862 - Antenna for GPS Navigation (R50/R52)
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
3 Faults Found:
