Skoda Swing Radio
Hi guys,
Come to wire a sub up to the car today but having slight problem. Can anyone tell me which one is the Ignition wire? So that when i turn the ignition on/off, then the sub will follow suit? I tried almost everyone but to no avial. :wall: :wall: :wall:
Any help much appreciated.
I think (and correct me if I'm wrong) it's all CANBUS controlled so there is no switched live from the fusebox.
I used to have an amp with the oem hu. I think it was in a switch live. Now mine's off the remote out of an aftermarket hu which comes on with ignition.
Two things I can think of, use a permanent live and on/off switch or the ignition, but it means amp will be on always when the ignition is turned.
