Leaking radiator
A leak has started on the radiator in my VRS on the drivers side and I'm just wanting to know if the switch for the cooling fan is on the same side to know if it's leaking from there or the actual radiator itself ?
Switch is on the passenger side so sounds like its a rad.
Excellent thanks Tech1e, new radiator it is then and may as well put a new fan switch in while it's out !
