Space in the bulkhead
I,m needing to run some power cables from my battery through the bulkhead and into the cabin. Does anyone know where this a space and where it leads to ?
Any help would be appreciated
Regards
John
12v socket splitter not an option? or wire splice from cabin fusebox?
I tried first to find a gap or hole behind the pedals, but couldn't find.
Then I used the passage of the hood opener wire (don't know the exact name)
Cheeers guys and nah it has to have a direct power supply from the battery
Inside engine compartment look at right hand side of bulkhead
Low down you should see a rubber blanking plug (VRS)
Remove plug
Inside pull back carpet and insulation in passenger footwell
From engine compartment push something long thin and sharp through hole occupied by plug
This should appear in footwell
Feed cable of required size
That's how I did it
I went through the rubber grommet that seals the bonnet catch wire, then there is a space behind this before you get to another grommet (see irfants pic but i went through the hole you can see, where the grommet has been pulled from) that then leads into the car quite high up behind the passengers side of the dash, then i just ran it all the way down the side of the car in the little gutter, you have to remove nearly all the plastic but its pretty easy they just pull off and push (hit hard) back in!
