Wipers not working.
Just bought a 1.4MPI classic but the front wipers don't work. I have read through the relevant threads and fuse 15 is fine, changed just in case and all other fuses OK. Rear wiper works normaly although I did need to reconnect the wash pipe at the bulkhead (position 1). Front screen wash works normaly.
Removed the motor and the rack is a bit stiff but loosened up with cleaning and lubricating and the motor works on direct 12V supply.
I'm thinking the column switch is the next to check but I did read about the bonnet needing to be closed. Seems to make no difference and I can't find the bonnet switch. Can anyone tell me where the bonnet switch should be?
Nigel
Hi the bonnet switch is normally on the bonnet lock/latch its self but not to sure so if anyone eles can just verify if im correct or not as im not to sure
I cant find any sign of an electrical switch linked to the bonnet lock. Anyone? Do all models have one?
