filler cap cover
is the filler cap cover easily removable? . . .hopefully getting it pinstriped and could do with comming off =]
Yeah, remove the screw on the left, a smalll torx screw iirc. Then pull the left bit out first and slide it out towards the back of the car. The rubber bit around the nozzle will just slide off also.
There will also be a clear drain away pipe running down towards the wheel arch, this should just pull out or can be pushed through the rubber bit if you wanted....
Edited by hutchysrs50
