Skoda Fabia Autoscan (VagCom)
Hi,
I have a light illuminating on my clocks and i'm not sure what it is. It is a steering wheel with an exclamation mark. So I plugged my Fabia into VagCom and done an autoscan. Here are the results:
Chassis Type: 6Y - Skoda Fabia
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01: Engine
Controller: 047 906 033 C
Component: 1,4l SIMOS3PA 00HSSJ4C
Coding: 00021
Shop #: WSC 13765
TMBNB46Y623310918 SKZ7Z0A0966152
4 Faults Found:
17526 - Oxygen (Lambda) Sensor Heating: B1 S2: Open Circuit
P1118 - 35-00 - -
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
P0140 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
Readiness: 0010 0001
Address 09: Cent. Elect.
Controller: 6Q1 937 049
Component: BORDNETZ-SG. 1S30
Coding: 09362
Shop #: WSC 13765
1 Fault Found:
01314 - Engine Control Module
49-00 - No Communications
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 6Y2 919 880 Cu
Component: KOMBIINSTRUMENT VDO V09
Coding: 16441
Shop #: WSC 13765
1 Fault Found:
Address 19: CAN Gateway
Controller: 6N0 909 901
Component: Gateway K<->CAN 1S30
Coding: 00012
Shop #: WSC 13765
1 Fault Found:
Address 44: Steering Assist
Controller: 6Q0 423 156 G
Component: Lenkhilfe 0004
Coding: 00110
Shop #: WSC 00000
2 Faults Found:
01290 - Reference Voltage: Steering Assist
29-00 - Short to Ground
Address 46: Central Conv.
Controller: 6Q0 959 433 C
Component: 0F Komfortgerát 0003
Coding: 00067
Shop #: WSC 13765
No fault code found.
End --------------------------------------------------------------------------------------------------
Can someone tell me what these errors are? I've had a search but none of the topics listed made any sense.
Edited by David Elliott
How new is the battery?
Couldn't tell you exactly how old it is as it isn't my car, was only purchased a few months ago. I'll ask and have her test a different battery in it.
The car would start before it was plugged into vag com. I done the first full scan:
These errors never showed up the first time. The second scan the car went weird and brung up them error codes. I then tried to start the car and it wouldn't fire, I removed the key and put it back in and it started first time. So I think: 01314 - Engine Control Module
Isn't a major concern.
The concerns for the car is;
4 Faults Found:
P1118 - 35-00 - -
New oxygen sensors?
Thanks for replying.
Anyone?
As far as im aware its a power steering fault, by the scan it looks to be something about it as well
"Address 44: Steering Assist
Coding: 00110
Shop #: WSC 00000
2 Faults Found:
49-00 - No Communications"
by the looks of it your steering assist is just a little low on voltage from the results on vagcom, i thought it might have been something to do with the engine immobiliser as that came up as a fault on vagcom but that lights a car silhouette with a key inside.
To be honest im just guessing but im pretty sure its something to do with the power steering, if you have an owners manual it explains all the dash lights in that, if not il have a look in mine tomorrow and get back to you.
I am new to this game and still finding my way with VCDS but had a very similar set of results, all of which cleared with a fully charged battery. Charge it up, reset the fault codes and have a careful drive in case steering assistance is reduced and then rescan it. See what codes have returned if any.
Nigel
Coding: 00110
Shop #: WSC 00000
2 Faults Found:
No owners manual :/.
Nigel
Was it the same error code?
Have you tried clearing all the codes, and seeing what comes back. Voltage issues could be historical and might not come back. Is the P.A.S working at all?
Nope I never thought at the time to just clear the codes and see what comes back. The PAS fully works.
