has anyone fitted clutch master cylinder
ive undone the single bolt were the bracket is and 2 bolts at the bottom is there anything else coz i can not get it to budge help please
I havent replaced one on superb but on others cars it is connected to the pedal usally by a clevis pin & r clip,have you removed this? also you will need to remove the fluid pipe connection from the master cylinder. Hope this may be of some use to you.
