Setup of timing as i have it slighly out :(
Hello all i changed my timing belt the other week and while doing it i left slack on the cam w pump crank side and tensioned it which i know ballsed it up because i tried turning it over and it wouldnt start i then took the glow plug out of cyl 1 with a metal rod found top dead centre, removed the pully wheel off the cam and moved the cams back with a wrench replaced the pully and started ok.
I have slight poor mpg when driving eco style and it used to pull hard from 1.5k but it seems to be slightly weeker now and i realy have to drive it hard to 4k to feel satisfied if you know what i mean where as before it used to pull hard from low rpm and i used to change at 3k when wanting to get away.
Is there any markings on engine casing crank pully and under the cam pully and pully it self so i can go by to set it back up to default kind of thing...?
Thanks for your help guys
Thanks man thats been real good help! :thumbup:
can some one tell me when looking at the pulley turning the cam clockwise or anti-clockwise is advance and retard? il have a play at the weekend then see if i can get it spot on.
im guessing clockwise is advance right?
Edited by VRS-Badman
