VRS wheel bolt dimensions
Anyone know the spec / measurements of the VRS wheel bolts ?
Cheers.
According to ETOS, bolts for the 17" wheels are M14 x 1.5 x 27.
HTH
Gray
Wont you also need to know the taper on the seat?
Yes, taper as well. Many thanks guys.
Changing wheels johnny?
Edited by Wilko251088
The seat on bolts isn't so much a taper, they're more domed?
like this spare I have for the Cupra
Gray
oem vag wheels are usually radius seating, whereas aftermarket wheels are normally taper seating. Beware of this as the wrong bolts can be a death trap. i.e. not properly seated bolts mean only a little surface is in contact, possibility of wheel(s) coming off.
edit: thanks for showing the pic Big Gray, that is a radius seating where it is curved. imagine if it is straight (taper) going into wheels which accept radius, and vice versa.
unforunately there is no legal requirement for a wheel expert/seller to know this, and not in the MOT test. a good/experienced wheel specialist should know this.
Edited by fabia55
