Maxi-Dot Help
Hi guys
is it possible to get the Maxi-Dot fitted after you have bought the car, just i didnt add it when i ordered it.
its a monte carlo if that makes any diffrence
thanks
Yes, it is possible and there have been a few threads in the past on this subject. Few dealers will do it and you will probably need to go to a specialist such as Shark performance. It'll cost at least £300, probably more. You'll get more info from other forumites soon, I'm sure!
Maxi-Dot fitment needs to change a control unit, re-coding etc...
Thanks a rang the dealer today and he didn't seem to have a clue, thanks for the quick response :)
If you can supply them with a new Maxidot unit, then ask them to follow the procedure for replacing a broken set of dials. I believe it is exactly the same procedure.
But as already stated, most dealers will not touch it. Have a look in the Octavia II forum and you'll find people who have had it swapped there and stories of dealers who will or won't touch the job. Shark is always a good starting point when Ben is back.
I think the immobilizer has to be recoded same goes for the keys. Not a simple job I think.
32KOFDATA is Correct on both counts and it is beyond the capabilities of VCDS.
But a willing dealer can do it following the procedures I mentioned.
thats bad news, a didnt no what it was until i was looking on here and seen that some dials are green and some are white with a better screen in the middle, ad rarther the white ones lol
