les.t
hi everyone .i have a small problem with my 2001 octavia. when i open
the drvers door the interior light does not come on, but will work on all the other doors , also the alarm that tells you that you have left your lights
on when you take the ignition key out and open door does not work.
thanks for help les.T :thumbup:
Welcome to Briskoda. My guess would be that the driver's door microswitch is faulty. Having just had a look for a standard door microswitch on my Octavia and not found one, I seem to recall that it is part of the door lock. These aren't cheap at circa
Spot on Denis in your diagnosis there mate.
i have the same problem and got quoted about the same price :(
What ever happened to the little plastic plunger. :(
i prefer this idea myself, bit cheaper too
And you could wire up your alarm to it. :)
genious!! :thumbup:
genious!! :thumbup:
Corse it never worked properly and you were forever spraying it with WD40.
