Drivers side front and rear sidelight out !
Hi all, recently installed led sidelights (they were only cheap ones to see what they would look like) and its somehow knocked out sidelights front and rear on drivers side, and i get the bulb error warning up. I figured it must be a fuse to of effected both front and rear so checked the fuse box and consulted the book checking all the ones to do with bulbs and no luck :( has anyone got any ideas or suggestions ?
Cheers for any help
deffo a fuse if both have gone out,.just plonk one of the bulbs in the other side to see if the bulb works if it does its almost deifnately the fuse, or as there led make sure there the right way round as they only work one way
False alarm just me being an idiot, it was a fuse but for some reason when i put a conti tester over it, it gave a reading, just swapped left and right fuses to make sure, and now changed along with a new better set of leds :) cheers tho.
