Electronic prob's with wiper system.
Hello friends,
I have a Yeti 1.2TSI (model 2012).
Immediately after delivery of the car (somewhere close to half a year ago), began a strange phenomenon - all the vehicle's propulsion, rear wiper wiping operation was one of his own.
Front wipers often would jump slightly up and then back where they belong.
I know that the system is supposed to cost the wipers only work if they are in - if not, they are at the bottom of the window.
Attached to the vehicle computer diagnostics (licensed Skoda garage of course), trying to locate the fault and is not found - time after time, again and again.
Six weeks after delivery of the vehicle - car audio system upgrade was introduced, which consisted of Component Front / amplifier and subwoofer. The radio is the original disc - Amundsen.
The garage says that the installing of the audio system is causing failure, so We disconnected the receiver and we pulled out the Fuses, which does not solves the problem - that still exists.
The vehicle is (for the second time in two weeks) over two days in the garage and the problem is present.
Of course the problem repeatedly thrown to the installer, when installing the system - worked for Audi / Volkswagen / Seat / Skoda and Porsche - was installing licensed by the importer (in Israel).
Garage argue that movement is a natural in front wipers, wipers reset operation that occurs on the third drive of the vehicle.
In my opinion this is a lie, in a friend's YETI - it does not happen. We tested it more than once.
Immigrants wipers him up only if they are in work. Any other situation - terms at the bottom of my front windshield without moving an inch.
Moreover, the various visits and many tests done - and twice was unable to connect the garage's diagnostic computer - computer accessories to the vehicle's comfort. Actually was not this or that communication between them, even after the workshop update their computer software newest.
I am aware that this phenomenon happens / happened Golf MK4 and in MK6.
In a conversation with a local taxi driver - uploaded by him that he had a similar phenomenon in his Octavia, but with whom she appeared as she also disappeared suddenly.
It should be noted that the problem appeared before installing the audio system,
It appears there is also a disconnect amp and Fuses - as I mentioned earlier.
What do you think could be the problem?
We tested the command and control lever handle itself - the systems work well, they do not malfunction.
Garage do not know what to look and certainly not solve the problem, and I'm starting to lose patience.
TNX,
Orel J.
I suspect you have an ECU Controller failure, either related to the Central Electrics - Controller 09 or your Media player (Radio) - Controller 2E.
I suggest you contact someone in your area with VCDS / VAG-COM to arrange Output Tests to assist diagnose the precise fault. I see you're located in Israel and our Briskoda website does not list anyone with VCDS there - it may well be you'll have to troll your local VW, Audi, or Seat Forums to find someone in your area. Good luck! :thumbup:
Is this not normal behaviour, intended to prolong wiper blade life by making sure they don't continually sit with the blade at the same angle all the time when parked? Mine does it.
I'm not sure I fully understand the issue, but ours do a little skip when we first set off.
I've read and reread the original posting, and think this is his "complaint":
Now if I'm right, then this is normal behavior.
Yes,mine does it , to stop the blades being stuck over on one side.
Very clever really ,unless your blades are stuck to the screen when it's below zero.
snap. Ours does this also. No fault, by design, hence why no error codes. Possible induces by a software update.
Hey,
the results >
VCDS Version: Release 11.11.0
Data version: 20111111
Tuesday,22,May,2012,10:27:42:54818
Chassis Type: 7N0
Scan: 01 03 08 09 15 16 17 19 25 37 4244 46 52 56 62 72
VIN: TMBJF65L2C6039506
01-Engine -- Status: OK 0000
03-ABS Brakes-- Status: OK 0000
04-SteeringAngle -- Status: OK 0000
08-Auto HVAC --Status: OK 0000
09-Cent. Elect.-- Status: OK 0000
15-Airbags --Status: OK 0000
16-Steeringwheel -- Status: OK 0000
17-Instruments-- Status: OK 0000
19-CAN Gateway-- Status: OK 0000
25-Immobilizer-- Status: OK 0000
37-Navigation-- Status: Malfunction 0010
42-Door Elect,Driver -- Status: OK 0000
44-SteeringAssist -- Status: OK 0000
46-CentralConv. -- Status: OK 0000
52-Door Elect,Pass. -- Status: OK 0000
56-Radio --Status: OK 0000
62-Door, RearLeft -- Status: OK 0000
72-Door, RearRight -- Status: OK 0000
Address 01: Engine (J623-CBZB) Labels: None
Part No SW:03F 906 070 JH HW: 03F 907 309 AB
Component:SIMOS10.12AH10 2662
Revision:--H10--- Serial number:
Coding:001900D6230400080000
Shop #: WSC33361 790 00999
ASAMDataset: EV_ECM12TFS02103F906070JH 004003
ROD: N/A
VCID:71E33876A0B2056
No ASAM data for:"EV_ECM12TFS02103F906070JH" (SK35)
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW:1K0 907 379 BH HW: 1K0 907 379 BH
Component:ESP MK60EC1 H31 0121
Revision:00H31001
Coding:913F200E09250503891004E4901FA040340000
VCID:79F30056F0C24D6
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW:3T0 907 044 BK HW: 3T0 907 044 BK
Component:Climatronic H18 0506
Revision:00001007
Coding:0000000002
ASAMDataset: EV_Climatronic A01010
ROD:EV_Climatronic_SK35.rod
VCID:7CFD1942F7F078E
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW:1K0 937 086 M HW: 1K0 937 086 M
Component:BCM PQ35 M 110 0651
Revision:00110 AC
Coding:44000AB8A00508C04010008219000164437000AE526D89605C8040000040
Shop #: WSC00005 440 99492
VCID:3A71DF5AB54486E
Subsystem 1 - Part No: 5L1 955 119 A
Component:SK356 26 0604
Coding:00F7B5
Subsystem 2 - Part No: 1K0 955 559 AH Labels:1K0-955-559-AG.CLB
Component:RLS 011111 05 54 0403
Coding:2730ED
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW:5C0 959 655 C HW: 5C0 959 655 C
Component:AirbagVW10 013 0613
Serialnumber: 003G6RA50UV%
Coding:00005438
ASAMDataset: EV_AirbaVW10SMEVW360 A01014
ROD:EV_AirbaVW10SMEVW360_SK35.rod
VCID:3261F77A65347EE
Crash sensor for side airbag; driver side:
Subsystem 1- Part No SW: 5K0 959 354 HW: 5K0 959 354
Component:S.Sens.Fahr.V H01 ----
Serialnumber: 3572MSME3D403466ZZZW
Crash sensor for side airbag; passenger side:
Subsystem 2- Part No SW: 5K0 959 354 HW: 5K0 959 354
Component:S.Sens.Beif.V H01 ----
Serialnumber: 3582MSME49290266ZZZW
Crash sensor for side airbag; rear driver side:
Component:S.Sens.Fahr.H --- ----
Serialnumber: 3512QSME52306300ZZZA
Crash sensor for side airbag; rear passenger side:
Component:S.Sens.Beif.H --- ----
Serialnumber: 3522QSME7016624BZZZT
Address 16: Steering wheel(J527) Labels: 5K0-953-569.clb
Part No SW:5K0 953 521 BJ HW: 5K0 953 569 C
Component:LENKS.MODUL 014 0140
Revision:FF010040 Serial number: 20111027101206
Coding:5080040000
ASAMDataset: EV_SMLSNGVOLWSXS A01004
ROD:EV_SMLSNGVOLWSXS_SK35.rod
VCID:75EB0C66D4DA296
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW:5L0 920 800 J HW: 5L0 920 800 J
Component:KOMBI H05 0607
Serialnumber: 00000000000000
Coding:120A01
ASAMDataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD:EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID:2E59E30A710C5AE
Address 19: CAN Gateway (J533) Labels: None
Part No SW:7N0 907 530 M HW: 1K0 907 951
Component:J533 Gateway H42 1623
Revision: H42 Serial number: 301011F2001359
Coding:356302
Shop #: WSC33361 790 00062
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW:5K0 953 234 HW: 5K0 953 234
Component:IMMO H05 0607
Coding:000000
Shop #: WSC00000 000 00000
ASAMDataset: EV_Immo_UDS_VDD_RM09 A03009
ROD:EV_Immo_UDS_VDD_RM09_SK35.rod
VCID:EAD1AF1A0D6476E
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver(J386) Labels: 7N0-959-793.clb
Part No SW:7N0 959 793 D HW: 7N0 959 793
Component:TSG FA H04 0400
Revision: Serial number: 0000121576715
Coding:011402208000231003
VCID:438FA2BEC28EC76
Address 44: Steering Assist Labels:1Kx-909-14x-44.clb
Part No: 1K0909 144 M
Component:EPS_ZFLS Kl. 68 3201
Revision:00H20000
VCID:346DF162572070E
Address 52: Door Elect, Pass.(J387) Labels: 7N0-959-792.clb
Part No SW:7N0 959 792 D HW: 7N0 959 792
Component:TSG BF H04 0400
Revision: Serial number: 0000121502052
Coding:011400208000231003
VCID:4281A7BADD94CEE
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left(J388) Labels: 7N0-959-795.clb
Part No SW:7N0 959 795 D HW: 7N0 959 795
Component:TSG HL H03 0400
Revision: Serial number: 0000121676733
Coding:010000200000531003
VCID:458BBCA6CCBAF96
Address 72: Door, Rear Right(J389) Labels: 7N0-959-795.clb
Component:TSG HR H03 0400
Revision: Serial number: 0000121677129
End.
I presume that confirms what lots of us have said.
As all have said this is normal behaviour and I think the rear one does it as well as I sometimes hear a clunk from the wiper area when starting off. Haven't checked the handbook as I can't be bothered and must admit I ignore anything not considered major ie wheels falling off :o
