Problem with break-wear light
My brake wear light keeps coming on, I have had the front pads checked and they are are only half worn, and break connector is secure, I had a problem with the reservoir cap so changed it still the same problem fluid level at max.
Start the car nothing, drive without touching breaks light come on without breaking or comes on after breaking.
The only thing I can think of is that there could be a wear wire sticking out of the front pad that has the wear indicator built in but I have started the car and nothing has shown then without moving the light comes on.
I have plugged in my vds and its only showing that the break wear indicator is lit.
Any further suggestions other than change the front pads
Had this on my wife's Merc shortly after having the pads changed, just needed the sensor wire repositioning apparently. Maybe your sensor wire isn't positioned quite right (On Mercs at least it is seperate to the pads).
Hi Mike, Another 250 miles or so and it will be there, will send you a photo when it does.
Making a list of things for you to do now LOL
1, fit none canbus HIDs, dial out breakwear indicator, and any other mods you have done LOL
Edited by skippy41
