PDC display
Now back a la frog! the pdc display doesn;t show the rear picture/location of objects etc - the sensor sounds when in reverse ie with trailer attched,
suggestions, back to dealer, demount radio unit and reattach cables/reseat plugs etc - Im at a loss!!
I presume it used to show the OPS before your trip?
Tony,
Have you tried the Microsoft reboot? (switch off, disconnect everything, leave for 5 minutes, reconnect)
Often seems to work on other things.
The official reset to factory defaults for a Bolero unit is:
Call up the Setup System Setup by pressing the range selector key
and the function key .
Resetting the factory settings on the unit
– Press on the function key .
– Confirm the following safety interrogation, the unit will be reset in the
as-delivered condition and all the stored data will be erased.
Ok guys, thanks for the suggestions, tried the reset route using the system button and magically the problem has now cleared itself - I didn't fancy getting the radio out etc, but needs must and it would have been done!
Once again the forum came rushing to my aid -- brilliant
salut
