fault codes were to find the problems on the car
got two faults coming up first fault,turn signal activation undefined swith condition
second fault,contact on ing starter switch undefined switch condition.were are the faults as cant clear the codes as they just come up again.were on the car are the faults if any body nows so i can sort them out.thanks ste
no one?
what codes did vagcom/vcds reports?
I might be tempted to suggest checking earthing points around the steering column initially.
found the ing switch problem just the turn signal activation switch fault
What was cause of the ign switch? As the turn signal one is going to be in the same area
the control module for the centrol looking
Have you checked all the ground connections behind the dash? If theres a bad joint somehwere, it can wreak havoc with the electrics, and bring up some stupid faults!
