more late 80s wiring
hello again,
this time its the horn, i'm a little confused by this though.
if i connect the horn direct to the battery it makes the noise it should make.
however, if i press the steering wheel horn switch the relay clicks and the horn makes a quiet pop noise. am i right i thinking the interior side of the wiring is probably ok but everything from the relay onwards is a bit screwed and only a tiny amount of power is getting to the horn?
could this be the relay itself happily clicking but not enough? if my understanding is right thats a possiblity? that the horn is popping seems like its just enough not getting enough power?
any pointers appreciated?
cheers,
toby
Edited by toby
not the relay, stuck a paper clip between 30 and 87 on the relay socket (helpful on-relay diagram eh?) and the horn clicked some more. guess its a bad ground now - any help on key bad ground suspects appreciated mind?
cheers,
toby
