288mm or 312mm disks and pads!?
Hi people, how do I know what size I have? Or are all fab vrs 288mm standard
288mm standard dude
If you have a Mk1 Fabia, (not sure about the Mk2) AFAIK, the Fabia vRS are fitted as standard with 288mm discs, the 312's you refer to are an upgrade mod carried out by their owners and are not a standard size. You can upgrade to 312's but that means new discs, pads, carriers etc. There is a thread on here (somewhere) detailing how to convert to 312's but to answer the question, unless it has been modded by a previous owner, yours will be 288mm discs.
Reason I ask is my calliper is like 2cm off the wheel and the disks are huge lol
Wheel off then tape measure time
Wheel off??? Just eye it up through the wheel, or from behind the wheel :think:
If the caliper is 2cm off the wheel, you've got 288's matey.
312's are more like 2mm off the wheel.
If you need to replace the pads and disc's anyway (dont know if you do or not), then get 312's, as it wont be that much more really, and worth every penny.
HTH.
Dave
Do I have to buy any adapters or anything boss?
No, just calipers, carriers, disc's and pads.
Cheers for the help bud :)
If your unsure, wack a picture up, we'll soon tell!
312s
