ICE Recommendation Needed
I'm looking for recommendations for an audio setup for my Fabia vRS, got about £150 - £200 to play with.
The only after market component I have so far is a Sony Head Unit (Sony MEX BT4700U).
I'm guessing what I need is:
Amp
Sub
Replacement Front/Back Speakers/Tweeters
I have no idea what brands are good or bad or what spec things need to be...Any ideas?
Mounting depth for the front woofers needs to be 62mm absolute limit. Otherwise they'll be supported by the glazing bar behind the speaker apperture.
It's common to run 165mm components in the front doors. I've seen adapters and component sets up to 200mm but I've not met anyone who's installed them. (Fairly sure they'll bolt up but NOT sure you'll get the door trim back in without hacking at it.)
Forget the rear speakers, their positioning and mounting is crap and they're tiny to start with.
Here might be a place to start...
http://www.talkaudio.co.uk/index.php/index.html/_/reviews/
J.
