Can oil temp be displayed on dash comp?
Hi,
As per the topic can it be done?
I used to have a mk II vw scirocco gtx which had a similar comp as my vrs (don't have maxi dot :0( ) which would display oil temp... Trip, mpg etc.
I only ask as the water temp needle seems to get to 90 c in 5 or so minutes.... Surely the engine oil wouldn't bet at 90 c.
I'm only interested as my scirocco lived a very happy life mechanically (198k) when sold and I'm pretty sure letting the oil get up to temp before the obligatory thrash helped.
Thanks,
Rob.
i have a L & K Octy 2011 model and yes i have the oil temp available through the maxidot
Not sure how true it is, or even where I read it, but I remember seeing something that suggested that VAG cars are set to show 90 as long as the tenp is vaguely near that. Apparently it's to stop people complaining or worrying if their car starts running at 85/95/etc......
if you're on variable service then yes, if you're on fixed and you have a numpty dealer that doesn't know how to code it then no.
This was discussed recently on the GOLFMK6 forum.
http://www.golfmk6.com/forums/showthread.php?t=36126
Hi,
Thanks Alkip,
Mines on fixed... So just need to find someone who knows how to recode and hey presto !
That's good news.
Thanks,
Rob.
Hi,
Thanks Alkip,
That's good news.
Thanks,
Rob.
Mike (holroyd) could get mine to show, suspect it's been locked down by the dealer :wonder:
