Front struts
How to remove front suspension any guides ?thanks
remove wheels, remove the 3 bolts in a triangular shape holding the bottom ball joint to the wishbone, remove track rod end, brake calipers and abs sensor...pop the bonnet, take off the plastic strut cap and undo the nut facing upwards to release the shocker (make sure someone has a grip of the strut when undo'ing the top nut)
