Remove rear adjusters in coilovers
What is the easiest way of doin the above? Spring compress the springs, unbolt, wind adjuster off or is there a better, easier way?
Dont need compressors just jack the back of the car up undo the two bolts (1 either side) that hold the damper onto the axle then the axle will drop down enuf to pull the springs out :)
If you have spring compressors there is nothing stopping you using them but it depends which you see as been less hassle for you.
