valeo clutch and solid flywheel?
I have been trawling the net out of bordem and came across this and just wondering is it any good? It does not state the clutch is performance but comes with a solid flywheel? Also it is pretty cheap. I know vag use valeo in some boxes so the make is good but just wondering if any body uses this kit? http://www.premiumau...arts-1616-p.asp
Thats a dam good price i reckon you could use a performance clutch with that too
i have a valeo flywheel in my car after doing an smf conversion, smooth as silk now and very responsive. However the bolts were longer and a diff thread to hold the pressure plate on to the flywheel than the bolts holding the original to dmf, so make sure you get compatible clutch kit.
