electric window fuse, replacement parts
my drivers side window has suddenly stopped working, no idea what the problem is.
So I checked the fuse, it's the 25amp fuse right?
I think I might have to replace parts one by one until it works again, by process of elimination.
Is the regulator easy to replace?
So, window switch, the cable, the motor, the regulator?
Any tips, shall I take the fuse out to be safe when replacing the motor or disconnect the battery.
25amp fuse is right ;)
Thanks.
I've checked both electric window fuses, both seem in tact. I hope it;s something simple and I don't have to change the motor..
whers the regulator..
