Fabia vRS's On Coilovers
Looking at coils for the Fab, weighing up if I need them or not. Did anyone with coilovers on their vRS need to use shorter drop links?
I didn't with 40mm drop at the front. I dropped this much as it mentioned all the wishbones etc run in a straight line for best handling and stops increased wear on bushes.
What P1TT8ULL said.
You only need drop links if you go really low normally when lowering cars. But as said above once you take the wishbones past the horizontal stage by going even lower you actually start to make the handling worse
