rear view camera(12v) to rear wiper blademotor that supplys 12v/14v
Hi i was just wondering if it is a bad idea to connect my rear view camera(12v) to my rear wiper motor that supplys 12v and 14v when the engine is running.
It is better to connect a rear view camera to the reverse lamp circuit, that way the camera will only work when in reverse. The camera will use very little amps so it should not need a upgrade of the fuse.
Hi and thanks for your quick reply Tech-Yeti is it dangerous if i connected it to the rear wiper blade circuit as it is near by to the rear view camera 12v + and - cables , if i had to connect these to the reverse lamp circuit i would have to add a extensio/longer cable and loop it all the way on the other side .
There is no safety issue with connecting to the rear wiper circuit, the fuse is quite capable of running a camera as well, the only reason I would choose the rev lamp circuit is just that it would only be live whilst in reverse.
Plus if you connect it to the wiper then would it not only work if you have the rear wiper running in that case?
Phil
Wipers are normally fed with a permanent feed and are controlled via relays and resistor circuit boards to obtain permanent, delayed and intermitent action.
...might give rear light crcuit a try ....could i just use some 0.75 lamp wire for the extention or.........
0.75 cable can take up to a 30w load with no problems.
..............................just got in my 4 rear sensors kit where are these supposed to get powered from???
From the circuit for either reverse lamp. The reverse lamps are normally permanently fed with 12v, and illuminate when the earth to that lamp is provided by the reverse lamp switch on the gearbox.
....could i hook the rear view camera on to one reverse light and the rear sensors on the other reverse light , does that sound right?
That should be fine, the time that the camera or sensors are on, should cause no overloading on that circuit.
....was getting ready to do the electric instalation only to find out that the fabia 3 has only 1 reverse light. :sweat:
Trying to figure out what is best to power reverse camera and the rear sensors from the 1 reverse light ? :wonder: ........or is it better to connect reverse camera to rear wiper blade circuit and rear sensors to reverse light??
