Fault codes
Hi,
Is there anyone in the S****horpe area who could read a fault code for me. I have engine management light on.loss of power, black smoke from the exhaust . Car is Octy 2 1.9tdi.
Found air inlet pipe not seated correctly. All sorted now. Anyone know how to reset the fault light on the dash!
If you've fixed the fault that was causing it the light should eventually go off on its own after a certain number of cold starts (Five perhaps??.) Or alternatively you could use a plug-in OBD fault code reader to clear the codes and reset the light.
