Please help
My traction control light on my vrs keeps flickering both when engine is turned off just ignition lights and when running but stationary if i turn the traction control off the light appears then flickers light then dim can anyone suggest any help :(
I saw this on a car at work once it turned out to be an altinator problem... Because the battery wasn't charging properly it wasn't giving enough power to the traction control. It wasn't on a Fabia and it's probably not that but could be worth a check
Any fault codes?
Theres no codes that come up not sure if its possibly that im not using a decent reader is there anyone local to the midlands area who has a good code reader ?
Have a look in the vcds / vancom section and see if anyone is near you I'm sure they will be willing to help!!!
Where do i find that section ? Sorry
