10mm Spacers
Those of you using 10mm spacers can you tell which ones please? Links would be useful too please. Decided today I defo need some on the front!
Are you planning to use them on the front or rear Chris? I believe you need a different fitment for each but not sure. I was hoping to get some TUV approved ones as there have been issues with some 10mm hubcentric spacers developing faults.
On the rear I hope
I think it needs it more than the rear
If they dont fit ...You can have first shout...I wont fit them on the front
The eBay link doesnt say its for a particular axle
http://www.dpmperfor...x15-p-9010.html
http://www.dpmperfor...x15-p-3538.html
Both with the bolts and available for next day delivery.
Damian @ DPM Performance
They are 10mm ones - any 15mm ones for the rear? Also are these bolt to the hub first then bolt through with the longer bolts or just bolt through?
Having had spaces in the past the bolt to hub option saves a lot of cursing when removing / refitting wheels!
I had a set from Ben @ Shark, and they fitted both front and rear?! I can't imagine why they would be different tbh, after all, you can swap the wheels front to back.
Thanks Damian. What makes the HR ones double the price? Are they twice as good? Anyone used the FK ones before?
  • Sponsor
http://www.dpmperformance.co.uk/fk-15mm-30mm-per-axle-hubcentric-wheel-spacers-boltsbr-pcd-5112-centre-bore-571-bolt-thread-14x15-p-9012.html
http://www.dpmperformance.co.uk/hr-trak-15mm-30mm-per-axle-hubcentric-wheel-spacers-boltsbr-pcd-5112-centre-bore-571-bolt-thread-14x15-p-3540.html
  • Sponsor
The metal and the finish on the H&R ones is better, all depends on your preference really.
Can't say that i would be bothered enough to pay double. You don't actually see them anyway so as long as they are equally robust then my money is on the FKs.
Spacers fitted...Easy job and fit perfectly
Looks better too :sun:
Front or back? Pics?
Rear wheels
Posted already in 'What did you do to your Skoda today'
