help please guys
hi
having problems with the new octavia 57 plate 2.0 diesel
car fault coming up with fuel relay problem
there has been a new relay fitted but still no starting
can any one please help out
lee
Sunday,22,July,2012,20:36:54:19514
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 36 42 44 46 52 55 56 62 72 76
VIN: Mileage: 167030km/103787miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 021 LD HW: 03G 906 021 LD
Component: R4 2,0L EDC G000SG 9184
Revision: --H07--- Serial number: SKZ7Z0G4389837
Coding: 0000072
Shop #: WSC 73430 790 00000
VCID: 6CDC485E4F90D69
1 Fault Found:
005441 - Fuel Pump Relay (J17)
P1541 - 000 - Open Circuit
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 167030 km
Time Indication: 0
Date: 2000.00.00
Time: 20:18:59
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00101100
Bin. Bits: 0
Bin. Bits: 00000000
Readiness: 1 1 0 0 1
Address 03: ABS Brakes Labels: 1K0-614-517-MK60-F.lbl
Part No SW: 1K0 614 517 AC HW: 1K0 614 517 AC
Component: ESP FRONT MK60-AT 0102
Revision: 00H14001
Coding: 0055938
VCID: 68D4344E5B68FA9
No fault code found.
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1Z0 907 044 S HW: 1Z0 907 044 S
Component: ClimatronicPQ35 110 0402
Revision: 00110021 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 4688DAF631BCCC9
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000005141422
Coding: E18A8F330004140000110D000000000000097F065C000000000000000000
Shop #: WSC 24064 210 92301
VCID: 71E2592A68B23B1
Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 310707 022 0601
Coding: 00055223
Shop #: WSC 24064
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 190807 046 0204
Coding: 00471077
Shop #: WSC 24064
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AA HW: 1K0 909 605 AA
Component: Q4 AIRBAG VW8 027 0900
Revision: 11027000 Serial number: 003B5D12PA7Y
Coding: 0020788
VCID: 6BDE4B424A9ED11
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 036 0070
Coding: 0002042
VCID: 810289EAD812AB1
Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1Z0 920 942 D HW: 1Z0 920 942 D
Component: KOMBIINSTRUMENT VD1 1612
Revision: V1612036 Serial number: SKZ7Z0G4389837
Coding: 0007401
Shop #: WSC 17029 210 94688
VCID: 3972A10A7042B31
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 120807F2000474
Coding: E981FF0E0002022303
VCID: 30649C2EA338729
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VD1 1612
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 E HW: 3C0 959 760 E
Component: Sitzverstellung 1101
Revision: 00005000 Serial number: 00000000000000
VCID: 2F669F52BE066D1
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 E HW: 1T0 959 701 E
Component: Tuer-SG 006 1204
Coding: 0001022
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
Shop #: WSC 73430 000 90108
VCID: 3668AA36415C5C9
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 81801A085283007F3F02050F4008DF96907C00
Shop #: WSC 73430 790 12345
VCID: 830E83E2C20EB91
Subsystem 5 - Part No: 1Z0 951 171
Component: Innenraumueberw.008 4801
Coding: 00000000
Shop #: WSC 73430
Part No: 1K0 951 605 D
Component: LIN BACKUP HORN H07 9001
Component: NGS n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 E HW: 1T0 959 702 E
Coding: 0001022
VCID: 3A70BE067544B89
Address 55: Xenon Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000007
Shop #: WSC 73430 790 08192
VCID: F4ECD03E97A08E9
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1Z0 035 156 D HW: 1Z0 035 156 D
Component: Radio FO3 004 0011
Revision: 00004000 Serial number: SKZ7Z4G0005035
Coding: 0000420
VCID: 336E9322522E491
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 J HW: 1K0 959 703 J
Component: Tuer-SG 006 1201
Coding: 0000144
Shop #: WSC 73430 790 1012544
VCID: 3776A7324656A51
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 J HW: 1K0 959 704 J
Coding: 0000144
VCID: 3874A40E4B48AA9
Address 76: Park Assist Labels: 1Z0-919-283.lbl
Part No SW: 1Z0 919 283 B HW: 1Z0 919 283 B
Component: Parkhilfe 4-Kan H04 0020
Coding: 0000001
VCID: 3D7AB51A646A8F1
End ---------------------------------------------------------------------
Edited by leetdi22
