Little Problem when installing a low camera (PAL) on Amundsen+
Hi everybody,
I try to install a reverse camera on an Octavia II 1.4 TFSI 2012, DSG7 originally equiped with OPC and Amundsen+.
I bought a composite camera PAL + a PAL to RGB converter dedicated to RNS315.
http://www.mgconnex.com/kit-camera-de-recul-ccd-skoda-columbus-amundsen-octavia-ii
I have modified with VCDS the following parameters:
  • Module 10 (Park assist) --> Byte 0, bit 5 from 0 to 1 (=provide camera info to RNS). I've let the bit 4 to 1 so that I have both OPC and camera menu on the Amundsen+.
    --> Byte 0 = 30
  • Module 37 (Radionavigation RNS) --> Byte 3, bit 6 from 0 to 1 (=camera installed)
Now, when engaging the reverse gear, the screen of the Amundsen+ lets appear the OPC image plus a new button for the reverse camera view. When clicking on this button, a black image appears with an "Options" button that is not clickable and that should correspond to the settings Color, Contrast, Light.
  • If I unplug the camera, I get an error in Module 37 (No video signal) when engaging the reverse gear. It seems that, at least, the synchro is received.
  • I also tried to replace the camera by an external PAL source (camcorder) with the same result (black image).
According to you, should it be a problem of VCDS configuration? Any idea?
For the moment I sent back the PAL--> RGB converter to the seller for testing it. No answer for the moment.
Thank you very much.
Regards.
Cepadjedje
  • 2 years later...
hi, how did you solve the issue? i have the same problem
greets
